MagnetoSound
pucho812 said:ON the non working channel, If I connect just plate on the second triode, I got around 105VDC. The moment I connect in the plate on the first triode stage, the voltage to each plate on that tube is even but way low. More over both plates are fairly even in voltage on the non working channel.
If I'm reading this right, doesn't that suggest some kind of short in the first triode?
What are the respective cathode voltages when both triodes are connected, compare to just the second triode?
