sahib
The basic description of robot is "a machine which carries out a specific task".
Therefore this mechanism whether it is electronically controlled or not can also be described as a robot.
Why do you need another micpre?
This guy can help you perfect your art.
For example. The controller I have is a basic 8 bit machine. If we limit the X and Y travel to say 300mm then we can move the mic in just over 1mm resolution. Or if we limit the pan and tilt movement to say 180 degrees then we can rotate the mic in 0.7 degrees resolution. If we make the pan and tilt uber quite then we can crate interesting phasing effects. ( Late Bob Brozman did that by turning his resonator in front of the mic while playing.) And as Abbey pointed out you can do these while sitting in the control room.
s2udio said:Why do I need a robot, ?
When I can do the same job in 15-20 seconds ?
I prefer to pefect my art myself.
