G
Guest
Guest
[quote author="SmG"]Brad, if you put two cardioid pattern mics back-to-back, you get a figure-8 response. The back parts of the cardioid response effectively cancel each other out, just leaving the 'circular' response each side. [/quote]
Oh yes, von Braunmuehl s principle.
I have Braumuehl/Weber s einfuehrung in die angewandte akustik
(Leipzig, 1936) on the table. Nice book Also stereophony is
inside.
But if we can make cardioid from two membrane microphone
via making back membrane without voltage,
this back membrane makes dummy capacity load and decrease
microphone noise figure by 6 dB.
For figure 8 we must have minus polarization voltage source.
Why is not better to do separate amplifier to each
half of Braunmuehl s transducer and possible operation do
in the mix pult. And would not be that two amps outputs
some kind of one point stereo ??
Possible effect: 6 dB lower noise, spare of DC/DC converter.
That are questions which Braunmuehl can not respond for me?
Can do it someone of yours ?
xvlk
inside.
xvlk
