Yes it is possible. Then you need to measure at the connection point between diode D1 and resistor R2So can I do this without unsoldering the capsule? I have now removed c 3 again
If you measure on the capsule, it indicates a much lower voltage due to the relatively small internal resistance of DMM, of about 2Mohm for exampleHere Upol is measured against GND
Did you measure where POL is written on the PCB?Upol-GND=52,2V DC
Is this still within the permissible tolerance range?![]()
Measure at all points in the image, including POL.should I measure gnd at the bottom of the board and pole at the top of the board?
No.Or do you mean I should measure from pole to r1 and r2 to poll
Because of the impedance of the DMM, the measurement at POL or Capsule is not real.gnd and measured with an angle-closed diaphragm 18,1V DC at pol
I am waiting for good news!OK, then I'm not going to try to get rid of the humming noise with the aluminum foil. I'm really excited to see whether something will change
Thank you very much for so much help![]()
The capsule is not adequately shielded, it needs a finer grille (also connected to GND)Thank you very much it still goes have a minimal noise of its own can be that it is from the fetch housing which material will be the best for a housing copper aluminum brass or steel ?
