I have a few notes for the next person new to these desks and tasked with maintenance .
The automation section has a nicad battery inside which lasts 5-20 years with regular use of the console.
If your H3000 or H2000 doesn’t see regular use, you should remove the battery for safety.
Its likely you aren’t too worried about the automation features of the desk and any show files stored on the surface are long useless at this point. Half of why you want to use the purple behemoth is tell all 5 people who are helping you flip the damned thing how awesome it sounds.
Without a battery you can’t save a scene, you need to do an unlock dance with the menu, but it works fine.
Put the battery in for every tour, take it out afterwards.
The automation section has only 1 place to swap a ribbon cable and relase the magic smoke. The only cable that plugs into the solder side is the long ribbon cable that plugs into the other fader modules.
This cable has termination resistors on either side of the run. One of mine was snapped off but in a way that seemed intact, and that took a minute to find. Sometimes the cable gets damaged by too much module insertion. Anyway, if you the automation screen says init instead of an act number and scene number, um check the fader ribbon cable for damage. Or the termination resistors, or corrosion on the termination pcb.
The fader modules themselves have a binary jumper system thats essential for the save automation, and seems important for the boot too.
For the first fader module connect jumper 1, module 2 make jumper 2, module 3 make jumpers 1 and 2, module 4 make jumper 3, module 5 make jumpers 1 and 3, its binary.
I had quite a bit of corrosion around the battery of one of our vca modules and its going to be a pain to repair.
One of our other modules shows the obvious signs of this same repair being carried out in the last decade, and I can only be thankful we are now keeping track of the battery leaks in our old Midas consoles.
