I am working on a very simple headphones amp for a mixer. The attached pdf shows my thinking so far.
You need to be clear what kind of headphone you want to drive.
To give a few extreme examples.
AKG K1000 - 86dB/1V @ 120 Ohm
AKG K240 Monitor - 90dB/1V @ 600 Ohm
Sennheiser HD600 - 105dB/1V @ 300 Ohm
Beyerdynamic DT-770 Pro/32 - 111dB/1V @ 32 Ohm
Sony MDR-7506 - 118dB/1V @ 63 Ohm
As you can see you have a relative SPL difference at 1V out of 32dB.
And you have impedance levels of as low as 16 Ohm or even lower and as high as 600 Ohm.
So for a "universal" HP amp you should be able to drive at the very least full output into 32 Ohm. Also, most modern lower impedance headphones need low (< 10 Ohm) drive impedance.
I would suggest to use a inverting mode Volume control (using a Fet Input Op-Amp may be desirable over 5534) to give a wide range of adjustment of gain, possibly with a switchable max gain.
See here:
Headphone Amplifiers
Further, many headphones need EQ and often some form of crossfeed is desirable. You can use DAW plugins or use suitable analogue circuitry, I tend towards the latter.
Parallel Op-Amp's have serious current limits.
You could try the so-called "O2" Design, with NJM4556, it may be "adequate" from an objectivist viewpoint (it does not sound particularly transparent):
NwAvGuy
The design could be extended with (say) dual NJM4556 as followers with 3R9 buildout resistors and an added "main" Op-Amp using for example OPA1656 which drives the NJM4556 Inputs and the HP output via a 10 Ohm resistor in a variation on the Quad "Current Dumper".
In this case the OPA1656 delivers 30mA with each of the 4 NJM4556 sections delivering 70mA peak for 0.3A Peak and full output of ~ 16V Peak / 11V RMS into 60 Ohm (less into lower impedances).
Noise at unity gain and volume full up would be around 1.5uV and thus ~ 137dB dynamic range re 11V Output. Distortion is mostly determined by the OPA1656 which is very low, with a 32 Ohm load as shown the load "seen" by the OPA1656 is around 328 Ohm.
Personally I would suggest using a discrete output stage using BD139/140 following the topology of the Neve BA640 Line Amp design with 1 Ohm emitter resistors running on 12V...18V rails.
Don't go with the "diamond transistor" output, based on my experience.
With ~ 180mA Iq you get Class A for 12V peak into 32 Ohm. With 45mA Iq you get Class A for 2.8V Peak into 32 Ohm. It is recommended to keep normal operating levels in Class A.
For Drummers the standard 12V...18V rails may be insufficient, you can move up to TO-220 output devices and run the rails up to +/- 20V and make a balanced Amp (with ~ 80V P-P output) and either use a 4-Pin XLR with a balanced drive, or stick to 6.3mm Jack and build a M/S matrix headamp with M driving the "ground" and L-R / R-L driving the Tip & Ring.
Thor
