MK-U47 - build thread
So you pretend that the informations on this page are false, and by the way, dany Bouchard would be a liar ? check this...
https://www.vintagemicrophonepcbkit.com/D-47.html
As per evidence, I try not to pretend anything and only sharing what one knows as fact maintains honesty.
btw, Oliver did introduce the tlm67/87 to U67 mod, 2+ yrs before max (i/o audio) conversion was introduced. Good for Max recognizing Oliver's nice idea and running with it. Also providing the use of lower filament vacuum. ( low upfront investment w/nice return).
quick little update, I've managed to make some room for the rather bulky Siemens & Halske caps in my MK-U47. Not the prettiest job, but it does the trick and the mic continues to give me goosebumps. It is a bit hard to see on the photo but I made a little aluminum bracket that the two caps are mounted on.
Little fun side note: upon moving the upper tube mount, I noticed that I had the tube filament supply wired on pin 3 of the first 6028 and then took that voltage directly to the second tube, instead of wiring this to pin 4. Must have been by habit from wiring guitar amps... This means that for the last couple years the mic was running on only one of the two tubes with an insane heater voltage - whoops :) Still this mic got many compliments, especially from Cello and Double Bass players pointing out this mic to have the best sound they had ever heard on their instrument. Needless to say I took the time to correct the wiring and also test out some new tubes I purchased recently (Philipps Miniwatt and Tung Sol 408A).
Hi. Just a question about the DU47 build: Is there a problem to use two 1.5uf 400v caps instead of the 1uf caps?
And what cables are rcommended for this build?
You need to measure the response of the circuit if you use 2x1.5uf. Otherwise you don't know how those will interact with the transformer you are using.
The difference would be in the low end response, varying this cap value could make all sorts of changes in the low end, probably sub sonics, create/reduce resonances. The original value is 0.5uf. I'm not sure why some people blindly "upgrade" this to higher value without checking what it actually does.
The same goes for the high value resistors, and other components. The point is usually to get as close as possible to the original.
I am with kingkorg.
Increasing the value of the 0,5 uF Capacitor will lower the low cut-off frequency and as such saturate the transformer earlier. This most likely will generate more distortion.
What you can do if you only have the two 1,5 uF capacitors on hand and get the microphone running closer to spec is to put the two capacitors in series. This will divide the capacity to half of its value (e.g. 2x 1,5uF /2 = 0,75 uF). You will get you much closer to spec... at least until you can access a proper capacitor.
I assembled this mic years ago and still works like a champ. Just a quick note.
same here! still tweaking it from time to time though ;)
next thing I'd like to try is having a foam base under the capsule to absorbing sound to have less reflections within the basket.
Can't find any pictures of original U47 with details on this, anyone?
If using a u47 type body you shouldn't need that for historical accuracy sake, but adding absobing pad at the bottom brings improvements most of the time. You can just try it, and decide for yourself what you like better. The absorbent material here usually controls some unwanted dips/notches in the upper midrange, but can sometimes cause them. So measurements or at least methodicaly, carefully executed a/b tests must be conducted. 1, 2 check, or simple vocal take type of test wont cut it.
kingkorg.
That's good info!
What would that absorbing pad be made of? Thanks.
I use a type of memory foam i got from my physiotherapist, have no idea what it is. Gus suggested once magic eraser, which works nice as well. I even used 3M's yellow earplug type of foam i got from some production scraps. Not too soft, or the waves at that frequency will just go through (typical mic wind/pop filter), to hard the waves will just bounce back and create potentially notch at higher frequency. Experimentation, experimentation, experimentation...
