georgerarnold
Active member
- Joined
- May 26, 2014
- Messages
- 26
TillM said:Before my NOS 408a tubes was noiseless, I put them in my Mic and burned them in for 3 Days nonstop.
Interesting. What sort of noise did you get?
georgerarnold said:Thank you that's a good and cheap place to start. I'll try it first thing.
The noise is a scratchy static noise, not constant it never stops for longer than a second or two.
Thank you. the 1.5k resistor didn't make any difference but I've been with a tech today and we have ordered other resistors to replace.EmRR said:There should be plenty of comments about the 1K5 type in this thread.
If it doesn't go away or change with different tubes, then it sounds next most likely to be a carbon resistor, there are a few in there.
georgerarnold said:Can anyone tell me what the wattage is for the carbon comp resistors in this mic? The 100k and 30k.
I replaced the other resistors and now the noise seems better but not totally gone.
Do you think it's necessary for them to be carbon comp for the sound?
I'm just going to replace all the cheaper components and if the noise continues then look towards the pricier ones.
Delta Sigma said:Whatever you have on hand should be fine. 1/4W. I'm assuming you're talking about R5 and R6 in the Neumann schematic.
Your tech probably wants to replace carbon comp because they're less reliable, noisier and change more with temp than metal film. The reason why they're used in vintage mic designs is because they can slightly colour the signal. That's why they're used in the audio portion of the mic like the load resistor.
You probably shouldn't continue replacing random components until you've burned in your tubes and replaced your capsule with a cap as Gus and Moby suggested. It's better to know what your problem is before you fix it.
georgerarnold said:Thank you for your reply. You're right, I will order the cap first.
Cheers.
Delta Sigma said:It doesn't have to be anything special. If you can get a cap locally in the 50-100pF range, that's good enough. The idea is to eliminate the capsule and is leads in your troubleshooting. Keep in mind, you can still have noise from your Hi-z section if the guy who built it touched it without gloves. Clean it as best as possible. Do not get alcohol on acrylic boards or styroflex caps if there are any; use distilled water.
georgerarnold said:Hi, sorry to bother you again. There are three cables coming off the capsule, one off the base and one from either face of the capsule. Can you tell me, do I need to disconnect all three of the cables and then put the cap between where the two cables from the face of the capsules were? Or how would you do it?
Thanks.
If you decided to sell your kit, I'd be interested.Hi folks. I need some help here. I purchased two MK-47 kits from IOAUDIO years ago - the earlier version with the green PCB, not black. I built the first one in 2011 using Max's build thread in an Equinox body with a Thiersch redline M7 PVC capsule. I thought I had saved the instructions with photos, as a PDF, but I can no longer find it. I'd like to build the other kit, but I could really use those instructions. I see another member re-posted the instructions for the MK-U47 on page 35 of this thread with most of the photos, but some are still MIA. I also found a link to dropbox with all the photos, so I could be able to reconstruct the instructions with all of the photos intact, but that's not the build I need. Does anyone have an intact build instruction for the earlier MK-47 complete with photos? Also, is Thiersh still selling capsules? I might try a blueline mylar M7 if they still are. If anyone could assist either with a link to the complete build instructions with all photos intact, or can send me a PDF of same, I'd sure appreciate it. Thank you.
Hi folks. I need some help here. I purchased two MK-47 kits from IOAUDIO years ago - the earlier version with the green PCB, not black. I built the first one in 2011 using Max's build thread in an Equinox body with a Thiersch redline M7 PVC capsule. I thought I had saved the instructions with photos, as a PDF, but I can no longer find it. I'd like to build the other kit, but I could really use those instructions. I see another member re-posted the instructions for the MK-U47 on page 35 of this thread with most of the photos, but some are still MIA. I also found a link to dropbox with all the photos, so I could be able to reconstruct the instructions with all of the photos intact, but that's not the build I need. Does anyone have an intact build instruction for the earlier MK-47 complete with photos? Also, is Thiersh still selling capsules? I might try a blueline mylar M7 if they still are. If anyone could assist either with a link to the complete build instructions with all photos intact, or can send me a PDF of same, I'd sure appreciate it. Thank you.View attachment 85692
What I know is that MK-47 is very close to Oliver Archut's design D-47 as I've built an MK-47 last year... Same 2 x 408A tubes versions, so I guess the MK-U47 should be close to the D-EF47 which uses an EF800 tube. I could be wrongMax (ioaudio) is not around this forum anylonger so could please someone explain what was the difference between ioaudio MK47 project and this ioaudio MK-U47 project?
Thank you so much
