MK-U47
ioaudio
vienna/austria
Shop closed, working on the next batch
MK-U47 Tube Microphone Kit featuring:
Costum Headbasket made by Flea with Pattern Switch
Brass made body tube and bottom bell, bead-blasted and nickel-plated
Stainless internal structure
Bv.08 Transformer with 8 seperate sections from my own production
My dual 6028 tubes single supply circuit
including:
body tube
bottom bell with power resistor mounted + internal structure
Headbasket pattern switch
Transformer + resistor board
High-Z board with screws, teflon isolators, shims for variable capsule mount height
solder lugs and subminiature reed-contact
Black rubber band for tube shock-mount
Tube deck + tube sockets, screws,
Wiring, yellow wire sleeve, shrink tube
Binder connector for mic and cable
Bv.08 Transformer
PIO and styroflex capacitors, resistors
To complete the microphone, you'll need:
2 x 6028/408a tubes
a capsule + holder
a single supply 105v PSU
a microphone cable (cable connector to mic included)
SOLD OUT
Los Angeles
When skylar's bodies are finished and I get my first mic done, I would likely be very interested in a second MK7 set depending on how the project turns out.
Jerry
Active member
Paoli, PA, USA
Amazing - I was just looking at the original thread yesterday and kicking myself for not getting on board.
Count me in for one if it goes.
Jim50hertz
Glasgow, UK
I'd certainly be in for 2 or 4 burnt in/tested EF86s for my two existing sets...
Are you thinking of offering parts for the PSU?
Jim
