terry setter
- Joined
- Nov 17, 2013
- Messages
- 175
Has anyone tried the BV-08 clone transformer that also shows up on the Alibab page cited above (https://m.alibaba.com/x/Axe1yZ?ck=pdp) ?
RaykingI am still searching the name and manufacturer of this capsule:
View attachment 133714View attachment 133715View attachment 133717View attachment 133716
*bought on ebay, Nov. 2023 for 22,99€
Hey, thanks!Rayking
Great joke! May be some translation issuesMackie Element EM-91C. On the package they say it is "Large-Diaphragm Condenser Microphone... built like a tank". I Think this is just another version of the BM-700 with small diaphragm cardioid electret capsule with fet. Saddle is made of flexible plastic. Bought from Cl4s 0hlson with quite good discount with mostly metallic shockmount and XLR cable (approximately same price as typical BM-700 from The Bay).
View attachment 138224View attachment 138225
I have not seen this kind of capsule wiring with only two cables (black (-) connected to S and G and red (+) to D) before. Is it a conventional way to do it?
It's because that version of the capsule has a built-in FET. It's under that PCB disc with all the holes in it.Mackie Element EM-91C. On the package they say it is "Large-Diaphragm Condenser Microphone... built like a tank". I Think this is just another version of the BM-700 with small diaphragm cardioid electret capsule with fet. Saddle is made of flexible plastic. Bought from Cl4s 0hlson with quite good discount with mostly metallic shockmount and XLR cable (approximately same price as typical BM-700 from The Bay).
It's my understanding that it renders the capsule less directional at low frequencies giving it a behavior in that respect that's more like a dual-diaphragm LDC (of course, I could be wrong ).By the way - what purpose this Holed Halo or Old Phone Dial shaped capsule holder serves?
I've seen this already on (around?) some other capsules (and was too afraid to ask).
Is it meant to condition or deflect sound waves somehow or just Look Vintage & Cool?
I was thinking along the lines of a BLM-ish attemptsIt's my understanding that it renders the capsule less directional at low frequencies giving it a behavior in that respect that's more like a dual-diaphragm LDC (of course, I could be wrong
Man, the number of microphones that capsule shows up in is astounding!Electro-Voice PL84 handheld end-addressed 16 mm OD electret. I like the form factor (and the rubber surround of the casule mount seems to provide decent isolation). Is there some premium capsule that would fit and predictably work well in this kind of mounting?
Excellent capsule, indeed. It measures quite flat and almost similar to the blue one with a mesh front. I'd say they are identical. Sensitivity when feeding it into a single-ended OPA Alice circuit is 10mV/Pa. I measured them together with two other capsules. On the picture, top-right is a bit too bright, even for my ageing ears. The one at the bottom-right is not particularly flat and has lower sensitivity. Worst one of all. And the most expensive...A Chinese $6 electret capsule. I quite like these with dark blue back and a reticle(?) instead of the usual mesh. Pretty smooth. (This one seems to have a solder blob on the diaphragm, but I probably did that.)
Thanks jp8 and the rest of the gang to keep this thread alive!Excellent capsule, indeed.
