Thanks for sharing! It adds to the confusion tho. Because if I connect the circuit this way I get +39dB of gain and a low pass filter at 12kHzThis is my BC3 circuit diagram on page5, but your schematic the R19 connection in your circuit diagram is different.
R19 and U1D+12 should be connected together, not to GND.
They oddly specified LL1539 to be used as an input transformer as it is a balanced driver output transformer really (must be an option as the schematic doesn't make sense otherwise)...I don´t know if I posted this already: https://mae.tcrcloud.de/index.php/s/rq8Kxt2A27Rc2c4?path=/Amek/Amek BC3
I have the test report and the internal memo for that. I just have to look through which folder it is in.They oddly specified LL1539 to be used as an input transformer as it is a balanced driver output transformer really (must be an option as the schematic doesn't make sense otherwise)...
I've modified one of my MZ-15-RN channels so that I can easily swap the Insert send between the original AT8 and my own PCB. Even with all resistances matched the original AT8 still behaves differently and I'm starting to wonder if the compensation caps of the two NE5534 did serve a bigger purposeFor reference: I've stitched together several see-through pictures of the PCB and will try to re-trace everything from scratch.
Update: it looks like everything is connected identically to the schematic.
Possibly traces to thin or spacing to thin- if the resistance/capacitance tolerances are that tight a slight variation due to trace width or stray capacitance might be causing issues?How do you mean "the lines on the board were probably too thin."?
