Is it wise to mount this resistor to the side rail, or is it advised to mount is only to the end cap of the mic body(equ47)?
I'd say up to you, and testing it, Aluminium may be better at dissipating tough....
could I 'fasten' the resistor using an epoxy instead of using a brass plate to keep it down? Just how hot does this thing get?
Not a good idea in my opinion, when you say Epoxy, you mean gluing it?
First Epoxy won't have a good mechanical attachement in case of whatever,
And will crackle or come apart with time, it's a mic, lots of things will happen
to it in studio......
I think this one heats up a little, so even that won't make the epoxy last forever,
even if it can take up some heat on paper...
And the epoxy Chemical may damage the resistor in time? Just a tought here....
I'd go for brass or aluminium plate, and a screw with a secured washer....
Leads isolated of course....
But i'm not an expert...
