madreza said:
Hi Guys,
I have 105V for the pattern !!! it's weird !
I Also get the same voltage for the light !
when Mic isn't plugged I have more than 300V everywhere !
what should I do ?
Haven't built mine yet, but 300V without the Mic plugged it's tottaly normal,
even if 300V is maybe a little High, but you could have a high Mains voltage so...
on Ioaudio's schematic, the Test circuit, has a 2.4K test load, wich is the Mic's
Equivalent resistance, and that's when you have 105V, when the PSU is loaded
with the Mic, not without.......
105V at the pattern, well i had same doubt when doing the PSU,
but don't forget that the relay inside the Mic has a resistance too,
and so it must be connected also.
105 at the light? LED you mean?? Normal to have 105V going there....
If it's jewel light, aren't you using a 6.3VAC line for it?
