This is the best view I have as the mic is in service.evanmurphy said:JamesW,
Your PSU looks killer! Any chance you could snap a photo of your point to point work from above when you have some time? I'm about to do mine on turret board the same way, but I'm still a bit of a newbie. I think I've got it all figured out based on the schem but it'd be nice to have something to compare it to when I'm done.
Deeply appreciate it if you do get around to it!
-E
Please be advised that these small package resister needs to be bolted down to help dissipate the heat. This worked well on the Equinox mic base and I also used thermal paste.drgrateful said:The solution proposed by JamesW a few posts above for the 1k5 resistor seems very clean and I would like to follow it. The resistor is Mouser#71-RH0051K500FC02
However, ordering just that from Mouser would be expensive in terms of shipping fee (I am in Italy). Could anybody suggest where I could source that resistor in Europe?
Matteo
JamesW said:]Please be advised that these small package resister needs to be bolted down to help dissipate the heat. This worked well on the Equinox mic base and I also used thermal paste.
JamesW said:evanmurphy said:JamesW,
-E
drgrateful said:I think I need some help in wiring the PSU. Hoping this will also be helpful to others, I drew the image attached, starting from an image posted earlier. I am going to use a 7 pin connector and GAC-7 cable. Is this wiring correct? My main doubt concerns the best way for the shield, B- and the audio ground to reach 0V...
Thanks, Matteo
Yes, I thought it would have been more clear the way I drew it, but you are probably right: I updated the wiring diagram.Denyle Guitars said:Assuming the pattern switch is near the XLR connectors, just take the wires from the switch to 7p connector.
I hadn't thought of that. Thanks for the suggestion.Denyle Guitars said:Since your using GAC-7, you can also ground pin 4, same as pin 3, for the same reason.
