Studio Mollan said:
Hi guys!
I've been using my pair of Mk47's for about two now and they sound very good indeed!
I'm comparing them to my Flea47 and although they are similar sounding the top end is a lot smoother in the flea. Also the flea sounds overal more polished and more flattering, it saturates more and better than the MK47's do, but i guess thats to be expected from a 5000USD microphone. The mk47 is "faster" more modern sounding i guess and compared to the Flea a bit harsh in the hi end. Its not harsh sounding at all though, just comparing to the Flea.
Im using the Skylar body with Thiersch red mylar capsule. My Flea has a Thiersch blue PVC and EF12.
Any ideas on how to stretch the MK47 towards the flea? I know its a different cirquit but maybee you can get a bit closer with different types/values of caps?
If anyone experimented on this id be very happy for your thoughts!
Also: Howecome the polystyrene cap is 10nf instead of the original U47 spec 1nf? I tried replacing it with a 1nf SilverMica. Hard to tell the difference, at least on this source.
Emil
I've tried a bunch of the usual suspect capsules in my mk47, i can tell you, IMO the blueline is the runaway winner in that regard, smoooooth is the top end, and has that chocolatey M7/u47 vibe(as i understand it), not a bright mic at all, just pretty as heck. I'm also on my 6th set of western tubes, i have hit paydirt with this last pair. I will get the aluminum 10k resistor to throw in here, as i've had the crackling on the first sets of tubes, but i attributed that to bad tubes? remember, DIY requires YOU to dial in/polish up your creations, i simply wouldn't trade my MK47 for a single clone out there.
