That's just nice sound :thumbsup:etiefenthaler said:here's a live recording to watch and listen on YouTube.
http://www.youtube.com/watch?v=xvKaHNFycj4
Pip said:So here is my tail sad but true. I have gone through 3 sets of 408a Western Electric tubes. What happens is the mic will sound fine for weeks at a time and then all of a sudden start making popping or crackling noises. Replacing the tubes with new to me NOS tubes has done the trick twice but here we are again. I don't mean taking them out and reseating them that has not worked. I tried that first of course but had to change tubes. I Know that tubes are a crap shoot. But was just wondering if anyone else has had this reoccuring problem as well?
As a side note I started out with JAN Phillips tubes but they sounded not good at all.
Winetree said:Pip, Do you happen to have a picture.
sliebers said:I wanted to report my findings on the 1K5 resistor swap as well. I originally had the sandbar 1K5 (included in kit) mounted with heat sink compound to the brass base of the mic. The popping and crackling noises would appear randomly after about an hour of use. I then wiped off all the heat sink compound and suspended the resistor in air inside the mic. The noise seemed to appear less frequently, but was still there.
I ordered an aluminum housed 1K5 10W chassis mount resistor and replaced. So far, the noise has not shown up. I have yet to do recording work with the new resistor installed. That will be the real test as the noises always seem to show up when you are getting the perfect take.
The sound of the mic is fantastic, the tubes are a little noisy on their own, but workable. My advice to anyone building this mic is to throw out the included 1K5 resistor and start with a chassis mount 10W.
Nice. Very helpful for getting an impression of the mics. Thanks!teacat said:
Im using the Skylar body with Thiersch red mylar capsule. My Flea has a Thiersch blue PVC and EF12.
