bradb
slick
Arno said:![]()
Please do explain the body![]()
zebra50 said:I am a vandal! It's an old Thiele M4 body, with the original circuit stripped out.
e.oelberg said:I'm still a bit confused why the stiffened bias you suggested was unusable with my psu. which is not te stock psu and should have good filtering.
sounds like low mains for the psu. what is your heater voltage directly after the rectifier loaded?
pH said:Nicely done Max! I had thoughts of perfboard yesterday, but rat shack isn't open on christmas.
I also suspected the hum coming from the close quarters of those electrolytics. I might eventually build your other psu, but this works well for now.
Wow, I really love the sound of this circuit/transformer. If it sounds this good with the stock capsule I really look forward to a good double sided one.
Paul
pH said:I'm getting 11.9v out of the rectifier.
