I've been using my MK7 with the stock capsule that came in the Tbone and it's been working without problems after sorting out a hum issue. Just got one of Dale's M7 capsules and did the swap. Nothing but hardship and head scratching since.
I'm getting either nearly no sound or loud rumbling until the voltage drains. I assumed I had a problem with the position voltages, but they check out correctly on my meter. I have a few questions that hopefully you more knowledgeable mic folk can answer:
1) does an M7 capsule have a polarity, ie. front and back? It looks pretty identical, and Dale uses the same color wire for both sides.
2) shouldn't the front diaphragm work in cardioid by just leaving the rear diaphragm disconnected?
3) can you damage a capsule by applying the voltages in the wrong polarity?
Sorry so daft, but it's my first mic, hopefully something simple I'm overlooking...
-paul
-paul
