ioaudio
yes, the sct700 is engraved.
one low-noise tube out of four seems reasonbly.
bradb said:Thanks Max...
If anyone else has found a good solution too, pipe up...
which is also the reson for your hum. you will need a proper transformer with the specified voltages.waldorfcave said:i also bypassed the two 4.3r resistors after the choke to get the right voltages, because with them in my heater voltage was to low.
bradb said:Skylar, did you try that smaller 9 pin socket?
