mikep
[quote author="colinmade"] I'm going to do a break out box with a switcher between original transformer, a good replacement and no transformer.
[/quote]
not a bad idea at all. also, there are many variants of the 57, some with an on-off switch. perhaps, if it is a double pole switch, that could be used as a transformer bypass? alternativly you could drill a hole and mount a switch right on the side of a regular 57. you'll probably have to remove the transformer and then re-install it. maybe I will mod my 57 afterall.
mike
[/quote]
mike
