Monitor controller accuracy
Aref
I' think this is the best forum for this type of question.
Since I started using a reel to reel (Studer A807) for coloring my music I realized there is a big difference in what I hear in the digital and analog domain. I used to listen to tapes attached to my converters (Metric halo 2882) after 2 conversions. Now I wan't a straight signal from the tape machine to the same speakers. Of course I need a Monitor controller. But the price of pro ones are crazy here...
How does the cheap monitor selector color the sound? in comparison to my converters?
I found the Realistic mixer (32-1100a), which is what I really want in case of features. Is it really so bad in terms of quality I can't use it? of course it's not balanced I/O, but can I mod it?
    20.4 KB
Have a look at passive monitor switchers. You probably don't need balanced outputs and you probably don't need a mixer
Here's a link to a list of controllers - they start at €24
http://www.thomann.de/gb/studio_monitor_controllers.html?oa=pra
Nick Froome
Thanks for responding,
I have a TC electronic level pilot and it was a good solution for straight DA to speaker controller, but now I want to switch sources.
Now I'm trying the Studer A779, but it colors the sound a lot...
Here in the US Broadcast Tools make reasonably priced relay based switchers. I would look at companies that make broadcast utility equipment if you want an off the shelf solution.
Velleman makes a little switcher PCB which looks good. I haven't used it but Wayne Kirkwood did and gave it a thumbs up.
https://www.vellemanusa.com/products/view/?id=500375
I don't know what application WK used it for, but the relays are 230Vac/5A, so they are unsuitable for low-level applications.
The answer to your problem may be a simple DPDT switch placed before your TC Pilot. What is it that you find necessary in this Realistic mixer?
Oops, wrong one. Try this.
https://www.vellemanusa.com/products/view/?id=526331
Even worse: 12A @ 30Vdc or 16A @ 230Vac
I guess WK was just interested in the control part, which is pretty nice . I reread what he wrote.
Suitable low level relays would be a drop in replacement or you could use the logic to control externally mounted relays.
