multiple clipping stages (and or units)
Marssound
Member
The Netherlands
Hello DIY world,
I have a question about clipping:
When soft-clipping a sin wave (for example with diode clipping),
the peak will become a little flatter and you can call this a kind of compression but it will also generate a waveform with
extra harmonics. the sin wave isn't a pure sin wave any more.
but what will happen if I clip this new signal again? I think it will not generate the same waveform but instead will
flatten the already flatten peak curve more. and if you do this several times in a row, you will end with a
square wave.
I want to know if this is true and applicable to audio music signals.
see picture with a test I did to show it works that way. well, at least it worked in a software wave editor!
    171 KB
compression would affect the whole curve, and preserve the waveform - clipping distorts the shape because it only act on part of the wave
adding clipping onto clipping and so on eventually approximates a square wave
I learned back decades ago when I messed around with some unusual clipping circuits I had zero success predicting what they would sound like.
You need to melt some solder and listen to the results.
thanks. this was what I wanted to hear!
my software test (see picture) was already a reasonable proof that multiple clippings in a row produce a square wave.
my point is the use of multiple saturation devices in my studio. I have been using these in series configurations for a long time.
the next test will be with multiple 19 inch studio devices to see what remains of a sine wave when I put it through multiple clippings.
so my goal is not to make a square wave (indeed a perfect square wave is just odd harmonics) but just to investigate and discover what multiple clipping units do to sound. how quickly will it go towards a square wave, etc!
If you just want to make a clean square wave the typical approach is to feed the AC signal into an open loop op amp or comparator. Cascading a signal through multiple diode clippers in series will experience a build up of noise as each diode clipper will have gain associated with it, so the noise from the first stage will get boosted by the next. Etcetera, etcetera, etcetera.
I repeat my suggestion if you want to know what running through multiple units in series sounds like, just do it.
