Actually by replacing that caps does not change the sounds too much but instead of useing different style of caps it will producing a different feeling of the sounds maybe cleaner or muddier , and I think the 50V could be an issue well just leave it in and try it , worst come to worst the cap might just blow up , I found that the Muilti Layer BC ceremic cap does produce a good result on cleaning up the Harsh in the highs , and I like it very much
also you should replace the Cap (2.2uf 250V ) to the nicest film cap you can find can also try to sub it with a 1uf 250V , and might as well replace all caps with better one that also produce nicer sounding and cleaner effect , but dont forget to replace the TUBE as well , I got 6AK5 , which is smooth
