Assistant
Active member
dakiniz said:How did you increased the Q range?
I would like to know that too.
I played around with Harpos Calculator for 12 Steps and tried to change the Tables "R99...102","R104...113" and "rR95...98" but i can´t come up with a Q-Range from 0,7-4 in 12 Steps.
Which Resistors did you use there?
Also i noticed the the Q-Range is reversed on Harpos Calculator and goes down if you turn clockwise but i guess i have just to reverse the order of Resistors or did i overlook something?
