My Transformers
[quote author="TomWaterman"]Bloodyhell!
That is ******* amazing...best project in the history of GroupDIY!
Congrats analag. You could probably sell a few of them.
Prepare yourself for all the PMs about how to DIY one now...
I'm in awe.
-Tom[/quote]
It's a lot of work, the end result is amazing. I'm more than happy with it.
Rowan
Rowan,
I mean this in the nicest possible way, and please read back to my earlier posts if there is any doubt as to my respect for you...
But would you kindly f%*k off!!!
(You're making me look bad!)
I mean...
ferfuxsake...
Jeezuz...
Stop.
just stop.
Right now.
No more.
stoppit.
bastard
:green:
Keef
holy **** Rowan, Gus and I were talking about you and how crazy you are today.. And you go and prove it!
That is top stuff man, this should stop a lot of people from giving you ****.. In fact I bet a bunch of them will now beg to be your friend!
:shock: *******.... :shock:
:green: :green: :green:
Edit: Please take this comment as total extreme jealousy ....... I moderated my language for the forum... :green:
29 tubes, selfwound transformers, 10 unit rack case....it's just too much to comprehend for me right now. And you did it all quite quickly did'nt you? Well...how long did you work on this beast anyway?
It's by far the best DIY project I've ever seen!
YEs, what do you estimate your hour count to be, including separate guesses at 'research' and at 'planning' stages?
Then we want a white paper.... :grin:
Most-excellent, Rowan. That's one Irie chassis!
I found that AC fils worked great from a hum standpoint because of the cancelling effects of push-pull, but I went to regulated DC fils on the 6BA6's anyway, because power line drift would change the emission of the tubes and the meter zero was never the same twice.
A small annoyance, but you can question whether it's worth the extra circuitry. The 670 used a Sola constant-voltage xfmr in it on the 6386's for that reason.
Again, kudos to you for this gargantuan effort!
Research and build time took a little more than two months. And it's
(30) tubes not (29). I have an 6A*6 on the inside, directly beneath the EL34.
Larr, I set the 6B*6's to conduct a "set" current.
analag
hello, i saw this crazy project just now!!!
woaow
do you have more pictures please?
how is the sound?
did you compare to the original?
thank you
It sounds amazing. I have not compared it to the original but this thing is fast with a lot of stopping power. Something really beautiful happens when I hard pin the VU meter to the left.
