My vision of Marinair T1454
KraftWerk
I decided to make a copy of the T1454 but I have some doubts. I believe the housing of the original T1454 is from mumetal. Also, there is a brass sleeve inside which is not easy to replicate so I Decided on the housing that Carnhill has.Does anyone know if this Carnhil case is also made of mumetal or is there some kind of lining inside? I made my own bobbin that has a layered shield..would it be enough for the first outer layer to be a copper layer and then a 0.1 layer of a mumetal like foil and for the housing to be made of 1 mm carbon steel?.please look the picture.
    649.9 KB
There were some early versions in a black can that might have been a light gauge mu metal can.
I doubt that the green can halves are anything special,
The brass things are nice as you can gently clamp the high nickel lams so you do not get distortion due to magneto restriction.
Does it make sense to wrap two coils with 0.05 permalloy strips? Will this interfere with the magnetic flux? Or perhaps place one or two layers of permalloy inside a container in a circular shape, a few layers around the transformer?...or both?
I acquired some strips, 0.05 mm thick and 2 to 3 cm wide...I'm waiting for them to arrive so I'd like to experiment with it a bit... I'm also wondering how to test its effectiveness?
you could try it, use your capacitor meter to measure between the grounded strips and any coil pin. take notes and then try copper foil, then nothing. there might be a concern of losing high end and phase shift and ringing when creating capacitance to gnd.
Maybe you need something like this?
    412.2 KB
Yes, I'm sure I need something tile that...where I can find it?
So far, the wire has arrived. The 80% permalloy laminations, identical in dimensions to DU2023, have also arrived. Additionally, the custom-printed coils have arrived, featuring a slightly different design. I am very satisfied with how they were made.
I am still expecting:
The enclosure
MuMetal for shielding, inside and around the enclosure
A brass support structure inside the enclosure
I'm excited to wind my first transformer for testing soon!
Here How it looks so far.
    961 KB
    1 MB
    938.6 KB
I. Bought Nickel stripes in 2 dimensions 20 mm and 30 mm. With one I will wrap around bobbin, same tape - to see what will happen, and another I will insert inside Can..
Must wait longer for metal fans and holders inside can...
Before I'm not planed to make holders - core tightener, but have sense, because I can nice tune transformer Wirth controlling amount of lamination squeeze..I hope this cc an apply to small transformers to...
Not yet choose material to fill can- resin, Vax, silicon...I know it must be soft..
Any suggestions?
Tool came today, ..I want to wind 4 PC's same time, so I can have stereo matched sets. I can't wait to start winding these small beauties.
For now, we have 50 and 80 percent permalloy and silicon steel DU2023. We have special bobbins, MuMetal, cans,Only waiting brass holders inside, crazy expensive, 500 EUR for 100 PC's only brass...
I used three materials: Permalloy 50, Permalloy 80, and a steel core. Changing the core affects frequency, distortion, and phase. My goal is to achieve a frequency response as close as possible to the original T1452. I need to slightly reduce the density of the secondary winding to increase leakage inductance on the secondary, thereby reducing high-frequency reflections. The first transformer sounds great, but not exactly like the original T1452. Today, I will continue with new attempts.
    2.5 MB
