Mysterious mixing console
Very impressive magazine project.
I'm 73 and have been building projects from magazines since I was about 15 and I must say that I've never seen a mixer project as well documented as this one, (mind you I don't read German unfortunately, just basing my comments on the schematics and BOM).
This could be the basis for a DIY analog console project of any size as it's easily configurable from a simple 4 in 2 out mixer to something of the scale that qspart has acquired. Most of the components are still available and there's nothing wrong with a mixer based on 5534/5532 technology. Could be a good learning curve for newbies or those looking for a sidecar mixer to compliment their in the box DAW. I might even build the mic pre just to see how it performs, always had a soft spot for the 5534.
Did a quick google and found the specs for the output xfmrs:
http://www.revoco.cz/data/datasheets/dbe1130c1.pdf
Would love to get a translation of the complete article!
Thanks qspart and Madman for bringing this to our attention and the pdf of the original article.
Some of the pushbutton switches are not working, and I’m struggling to find replacements labeled as Elma 19-482 in the parts list. I’ve searched online but haven’t had much luck locating this specific model.
Does anyone know of a compatible switch or where I might be able to source these?
Additionally, I discovered that there are no line outputs for the 13 mic/line channels , there’s line outputs only for 4 aux and 8 group channels which wouldn’t be enough if I decided to record a band on it . so I’ve ordered 12 UTM3524 output transformers to add line outputs, along with 12 VU meters for some modifications.
One more question: would it be beneficial to replace the 4558 opamps with 5532s? The power supply +-15 volt rails has 22A each should be capable of handling the extra load from the 5532s.is there anything else I should consider before proceeding with that ?
Thanks in advance.
[I’ve searched online but haven’t had much luck locating this specific model] -- Are there any indications/markings on the switches themselves? Can you provide some clear and well-lit close-up photos?
[would it be beneficial to replace the 4558 opamps with 5532s?] -- Probably. The slew-rate response will go up and the noise-floor will probably go down. However, you will probably also need to add some power-supply bypass capacitors at each chip and it may also be necessary to add some circuit compensation capacitors on each chip as well. One of the "Circuit Designer Dudes" on this forum will be far better to advise you about this than I am.
[The power supply +-15 volt rails has 22A each] -- Are you sure it isn't -- 2.2A -- instead? 22-Amps is enough to run your clothes dryer!!! Is this console connected to its own 30-Amp circuit-breaker in your mains-box? It seems as though at that amount of current-draw, your hourly studio rate will need to be rather hefty, just to pay for your electrical bill!!!
[along with 12 VU meters for some modifications] -- In case you -- just might -- need some manner and/or type of an enclosure or meter-bridge panel for your VU-meters, you can let me know if you need any assistance, OK???
