Interesting, choice of transformers.
Since I have been doing this mod which will take some time to complete. Here are a list of transformers that people have used .
Stock unknown China transformer 10:1 Nady TCM 1050,1150, Apex 460, and others. Has anyone noticed how the capsule design appears. It looks as if they took two capsules and joined them together to operate as one. My other studio mics have one capsule with a front and back diaphram.
1. Lundahl 1550 , 4:1
2. Cinemag 2480, 11:1
3. Haufe T14/1, 11:1
4 Cinemag 96322, 8.5:1
The Haufe T14/1 appears a good choice because of its size , I'm going to try this first to see what type of results I get . It is also a humbucking design. Oliver at TabFunkenwork sells these in two flavors as does Haufe in Germany ( standard, and extra bass response.)
What about capsule upgrades. Peluso , 797 or 32mm stock ?
How is it determined what thickness of capsule is contained in the mic ?
Honestly ,(like Gus from NJ suggested in earlier posts) I would really like to get these mics gutted and do a vintage clone from ground up rather than mess around with a cheap design. Difficult to source parts though. Especially the high Meg Ohm resistors, and good choice of mic capsules.
After recently reading some information about cables, it is quite possible the cheap cables that accompany this mic may also need to be changed out. Apparently this has a effect on mic timbre.
After trying different tubes, 12AT7, 12AX7, 6072 vintage and modern types. I found that 6072A low mu triod tube allows the mic less self noise and just sounds better to me with the metallized polyprolylene cap mods I have performed. I actually used a new Electro-Harmonix 6072A and ran it in the mic for about a week straight. the longer the mic had run the better the sound , really important to let the mic warm up for at least an hour. I also removed cap C6 100uf/25V. C4 was upgraded to a .01uf/400V Siemens Met. Poly cap ( orig was a 1000 nf or .001uf/1KV) . I plan to try to change R8 from 270K to 20K next, these and other mods were suggested on the TCM 1050 mod thread. Both the 1150 and 1050 are the same tube circuits packaged in different mic bodies with different pcb's. Esentially the same mics and same component values for both. Although , I did notice the 1050 had a 1000nf or .001uf/630v Polytyrene, in place of a metallized film cap (.001uf /1KV) found on the 1150. This component is marked C4 on the 1150 and 1050 mics.
Though the mods have opened up the clarity of the mics mids and highs , the bass response still suffers as was pointed out in the Gus' 1050 thread.
If the bass response could be improved this would be a better sounding mic, no doubt. Maybe a capsule and circuit change is inevitable, afterall. Lets see were this goes ..... ?
