grid_stopper
- Joined
- Mar 2, 2016
- Messages
- 204
That is a brilliant idea and a decent excuse for buying a 3D printer . You could make the base in one colour and then change filaments and add the legend on top. Very novel. Thanks for that.
what i like two do is 2 different stl's(the file that contains the 3d object. one contains the actual faceplate shape, the other contains whatever text or graphic you want inside the faceplate. print the text/graphical element first, leave it on the bed, and print the second part over top. for the best result, you should create a 1 layer thick cutout in shape of your text/graphics on the first layer of the faceplate object, so the extruder wont peel up the text you previously printed.
a little bit more effort, but the results are fantastic, and it truly doesnt take long at all, as your only printing a couple layers. most of the work is in creating the two separate objects.
