I play the acoustic upright bass in a jazz trio + 1 or 2, and we routinely make multitrack recordings of live gigs. Recordings are made by the house engineer on house equipment. My bass sounds pretty good acoustically and at least 1 of my 2 pickups get tracked as well as a cardioid mic in front of the bass fairly close to the F holes on the G string side. The issue is bleed from the grand piano on the right and drums on my left and probably my monitor on the floor behind me.
I'm thinking of trying a vocal shield around the mic. I don't want to block too much of the bass visually because the audience likes to see it. That may be my best option.
I've also hung a lipstick mic between the legs of the bridge with rubber bands but that doesn't provide any isolation. It works well in a booth though.
I know sound is reflected off the belly of the bass into the mic so outside of setting a plexiglass barrier on the floor I don't know if I can do much for that.
If you are willing to share any tricks or suggestions on how to keep the drums and piano out of the mic without blocking the view of it from the audience please share. If I can drop them by 10db I'd be happy. The drums are the main issue. The drummer uses his kick like a rock drummer.
