how many do you need,,,,?john12ax7 said:Does anyone have a source for replacement nuts for Alps pots? I need M7 x 0.75 with a width of 11mm (see attached pic).
The 10mm width is common and available, but no one seems to have/use the 11mm version except for Alps.
I still have piles of 16mm 1x100kB (linear)pots, and 2x50kB (S taper) from my old kit company. These pots are a few decades old so will probably end up in a landfill, sometime after I do...john12ax7 said:Found some Alpha RD09 pots in the parts bin, but they too are 10mm, not sure about the RV16.
I probably need 100-200. But if the Alps pots I need are available, that's even better.
john12ax7 said:Sent you a PM but seeing now you replied here. Those values wouldn't work, but maybe the nuts would.
It's the perils of trying to do small scale manufacturing with off the shelf parts.
