pvision said:£240 per speaker
moamps said:I forgot to ask you did you hear the noise from both drivers, LF and HF?
moamps said:Do you have any information what the fault was and what they replaced?
Then there is a small chance that the problem is in the HF power IC, but the fact that no noise is heard from the LF driver may be caused by the LF driver not being able to reproduce that high pitch sound.btyreman said:the noise appears to only be coming from the tweeters, and I'm having a different issue with the left one, that one the noise doesn't go away, but the right one it does go away after about 6 minutes as I posted in the recordings., hope that helps.
Thanks.pvision said:No and no
Ben
scott2000 said:If you know anyone with an LCR meter you could check those removed caps just to see if they've gone off. I suppose an ESR meter would be great to check them in this scenario as well...
btyreman said:the right speaker is re-capped all the red and blue ones, and it's working perfectly again, no noise whatsoever! even when you put your ear right up to the speaker, silent, exactly as it was brand new, I have the second speaker board to re-cap, thanks in particular to moamps., will report back to let you know if that works as well, this has saved me a lot of money, I'm very happy.
Khron said:That's great news!
Out of sheer curiosity, any chance you could post a photo with the removed stock caps, from either speaker? I'm mildly curious what brands and series they used (in these eyewateringly-priced monitors)...
