Le Roux said:Haha!
Thanks for pointing out my dumb error :-[
Back plate and rear capsule reverse. WOW
Dead quiet and sounds amazing!
Thanks for your help and Danny for the project!
Neil
There was no specific M49b body.Sorr said:Are those M49B bodies still available?
cofrus said:Hi ,
Yes I’m having the same issue with the
Studio 939 M49 mic body. As recommended on Vintagemicrophones web page.
The holes don’t come close to matching the PCB, because the barrel has a diameter of 65mm and the Vintagemics PCB is 60mm.
Also the total depth between the base of the barrel and the grill mounting is only 38mm whilst the vintagemics design requires a minimum of 40mm.
Stumped.
TillM said:You have to modified it.
But that’s not the big problem.
Just buy a round acrylic plate with 3mm thickness and drill it for your needs.
Ohms law is your partner here. You have to check the datasheet about the tube heater current and to calculate the dropping resistor. That's all. Calculate it 3 times before you proceed.Ralf said:Answering myself: Further up in the thread it was reported that the unloaded heater voltage of the PSU can indeed be in the neighbourhood of 22V, but with a tube connected it will drop to around 6V. This seems like too much of a gamble for me for a 600€ tube.
I am thinking about crocodile-clipping lower values into R4, then slowly working my way up once I have the tube connected just to make sure I am not hitting it with more than 4V. Does anyone have any experience with good R4 values for an AC701 tube?
you should also calculate the wattage for the resistor. 20v drop it's gonna burn it in the heat. Don't be shy with wattage, you don't want to overheat it.Ralf said:Ha! Now it all makes sense, thanks. According to the AC701 datasheet and Ohms Law the heater will present a load of 40 Ohm. This means the voltage will drop to around where it should be when that load is in parallel with R4. According to my calculations it wouldn’t hurt to go down to 330 Ohm with R4 in order to get more usable range on the heater trimmer pot and to make the “death zone” for the tube a bit smaller on the pot.
The transformer you used and gave a link here is not Bv.11 but some T14-1 modern variation. Bv.11 use the same sized lamination core as the Bv.08, so called UI30/25 and it's much larger than T14-1. Of course, It does not matters regarding signal level (it affects headroom), ratio is the important. But, with UI30/25 you are in the "safe zone". Ratio should be 7:1 or 10:1 depending on the M49 revision.Nele said:Hi everyone,
I'm finally getting around to finishing the build of the M49B with the 6s6b-v tube. I have a few issues:
- the mic is working correctly, patternswitch is working but the output signal is really low. I'm using the BV11 by advancedaudio but it is really tiny compared to the other BV11 versions I see in the pictures. Is this really a BV11?
- I can't get the heater voltage up to 6.3V. The maximum is 5.9V. I'm using the psu that came with the other pcb's from vintagemicrophonepcbkit.
- I accidentally connected the mic without setting the heater voltage first so the first few minutes the tube got the full B+ but very low heater voltage. Can this have damaged the tube?
