Hello Dany,
So I have just started populating the board and realised Mouser made a cock up on my order and missed some of the parts out of the BOM!
I have ordered the parts that were missing so I am waiting for them, not a problem as I uave my U87 to be finishing off.
I have a few questions regarding the build;
1) I noticed there are many additional parts for BC5578 and BC5478. What is the aim here? Do i need to measure them like the JFET in the U87 build and pick a certain on based on their measurements? Should they be as similar as possible etc??
normally you would check for highest HFE on these but they are already garanteed , so keep those as spare as those fairchild transisitor wont be here for muc much longer
2) Resistors (R18+R19) and (R20+R21) also have additional parts. Do these need to be matched within a certain percetage like the ones in the u87 build? I can use a wheatstone bridge like i did there if thats what they need? What percentage do they need to be matched to?
0.4%
3) On the schematic the Styrene at C2 reads 18pf, the one from you has 20K printed on it? Is this ok?
yes it is ok it is 20pf with 10% tolerance = 20K
4) On the schematic R5+ and R5 suggest 33M or 2x68M, the one in the BOM is 30M. Is this ok?
if you have R5 at 30M this is ok use only R5 if you have 2*68M then use R5 and R5+ as they are in parralele
Thanks for creating these builds they are quite marvelous
I cant wait to get both my U87 and U47FET working and in use in my studio
Regards,
Matt
