- Joined
- Jul 15, 2009
- Messages
- 2,312
JessJackson said:Question on the P.S
I wanted to bypass the PCB for modulation.
Is this correct to link all together:
[[ XLR pin 3 > Chassis > Pin 7 > Pin 3 > PCB Gnd ]]
Reason I ask is because of switch on pin 3 to pin 7, default on schematic shows open position yet still goes to chassis regardless.
could you explain the modulation thing ?
if you tie the cable shield from the cable to the mic body then pin 3 Sheild and pin 7 0V are at the same level , the SHLF jumper wich is open by default allows to lift the shield or not if your shield jumper is on or not , hence you can have a floating shield or not, just permits 2 ways of doing things as somtimes it can help on RF wierd situation, if you actually dont tie the pin 3 to pin 7 on the mic pcb or mic body you can have both functionnality operated with the jumper
but basically if it is now tied up to the mic body then ou are good to go ,
hope this helps,
Let me know .
DAn,
