Is it normal for the B+ voltage to read at approximately 175 at the little pad in the mic with the B+ pot set to least resistance?
How much is the voltage with the POT on Max position?
The pot should give you adjustment to get the correct voltage, 210v, if things are correct.Is it normal for the B+ voltage to read at approximately 175 at the little pad in the mic with the B+ pot set to least resistance? The output voltage before the pot is well over 350v, so I don't think it's the transformer. Can I just drop the value of the resistor in series with the pot, or should I be looking for a mistake?
I have just noticed that there is a small negative voltage (-25mv) and negative resistance (-15ohm) between the chassis ground/safety earth and the mic body, but only when the mic is on. I can touch the mic without getting shocked, but I'm worried that this is unsafe, and I'm not quite sure what is wrong.
I have checked voltage drop across the cable. It is negligible. I will check the resistor values and current draw, thanks!The pot should give you adjustment to get the correct voltage, 210v, if things are correct.
You should double check R1,R3,R7 and confirm that the B+ in the power supply is also 175 (no voltage drop along cable). If the psu is built correctly, the mic is drawing too much current.
You can check the B+ current being drawn by the mic by measuring the voltage drop across the 150k plate resistor. The 'correct' values from the schematic are 210-75=135v, which is 0.9 mA
Yours is going to be different.
Something is off that your B+ is dropping more than expected.
The mic ground should be connected to the chassis ground. You need to doublecheck the ground scheme
I swapped resistor coupled to the potentiometer. 22k instead of 56k gave me that result. Sorry for not clarifying.Is the b+ 255v? I thought it was 175v?
Yes, galvanic isolation. It is a safety feature for your house, humans and animals. It is mandatory by law in Europe. If something happens, no insurance will pay and you will go to jail for any personal injuries. Don´t do it!Hello everybody,
I'm in Europe with 230v on mains. I don't understand why the guys are using the mains transformer to do 230v to 230v.
To clean possible DC current from the outside?
I have an incredibly stupid question I’m sorry but how do you know which tubes to use in these Poctop builds? For example, do you use the u67’s classic ef86 tube? Or something else?
Thanks. So from that I gather that unless specified on the product page at vintagePCB, each mic model would use the same tube that its vintage counterpart would’ve used. I’ll roll with that for these builds (looking forward to trying one!) and go from there.EF86 and/or EF806
Yes, the resistor is not on the schematic. It is in the build guide for the PSU and the BOM. It is in series with the potentiometer, creating max resistance of 80kish ohms. I had a 22k resistor on hand and stuck it in there to see if that was enough, the 255v is the undesirable effect. I changed tubes and put a new 25k pot in, and was able to get B+ to 210v. ThanksWhich resistor is that on the schematic? I don't see a 56k, unless it is the trim in parallel with the pot. But if the pot is at 0ohms it won't do anything. And why bring the b+ way up to 255v? I'm very confused
Can I use these 797 Audio K67 capsules in Poctop's u67 build?
