fsalter
The 2N3819 orientation on the PCB is fine. I built many of these.
fsalter said:The 2N3819 orientation on the PCB is fine. I built many of these.
PG_Sax said:Hi there,
Just planning a build using D87 pcb by Dany.
Just wanted to check something, is it fine to leave the variable resistor in place once you've set the bias? Or should you replace it with the correct constant resistor?
Also in setting the bias is the multimeter method (11-11.5v) enough, or should the 1k test tone method be done afterwards to optimise for headroom / thd?
Many thanks!
RuudNL said:My Neumann U87 microphones use Texas Intruments 2N3819's.
gyraf said:..the last two batches of 2N3819 I bought turned out fake, just some rebranded generic NPN transistor..
They were branded, with laser marking:
(Fairchild-Logo-F)
BJ12
2N3819
roger.unc said:How did you know they were fake? They've been hard to find and the ones I purchased off of Ebay have the Fairchild logo as well. I am, to say the least, suspicious. Thanks.
poctop said:There is Copy ,ok this is a vintage project LOL
Dan,
The first batch of JFETs I bought from eBay came from China and were indeed fakes and not up to spec. Then I bought the JFETs from this exact seller in the UK you linked to and they worked great!PG_Sax said:But I saw these also and wanted to check whether they are suitable, didn't want to ask Dany again as I've already bombarded him with a fair few emails.
These are Fairchild 2N3819 am I right in thinking these were used in the original U87i?
https://www.ebay.co.uk/itm/2N3819-FAIRCHILD-N-CHANNEL-JFET-TRANSISTOR-x5PCS/273131663608?epid=1017213417&hash=item3f97ea70f8:g:guMAAOSw4vJau3gR
