kante1603
You're welcome.wthrelfall said:thanks
Wasn't it you with that figure eight problem?How did it work out,problem solved?
Please let us know,we all want to learn of it.
Thx,Udo.
kante1603 said:You're welcome.wthrelfall said:thanks
Thx,Udo.
O.K.,if it is back capsule related the omni mode won´t work either.If it really does work (check sound on the 90 degrees angle and the slightly lower level in omni) I would recommend a deeper search in the area as shown in the pic.wthrelfall said:yes it was me. Still not resolved, but I suspect that the connection I have from the rear backplate is to blame. I haven't had time to check properly, but will do soon..
Very nice indeed,a bit too much low end though,but that is more about how close you´ve been (proximity effect) and the mic position.tskguy said:Let me know your honest opinions I would like to tweek the capsule if needed!!
sproto said:OK, complete noob question here so, apologies up front.
I have build several compressors and mic pre's but only with some hand holding (at least slight instructions). This is my first Mic build. I have been lurking (admittedly have not read this ENTIRE thread). Can anyone point me to a place with general build guides for this? i.e. transformer, then capsule, look out for this etc. etc?
There is a tone of information here but from what it I have read it mostly pertains to troubleshooting once the mic is assembled.
Any direction is greatly appreciated.
S
tskguy said:And here is the same vocal in the mix, This is again pretty dry just some delay.
http://dl.dropbox.com/u/55530129/u87vocalMix.wav
You mean biasing in advance?Well,if it works-why not,hahahaha.......poctop said:you may want to start biasing again just in case something would show up to your door, ;D
Keep me posted,
Dan,
