kante1603
My combination is peluso pk87 and T13 for trafo.
Udo.
Udo.
kante1603 said:My combination is peluso pk87 and T13 for trafo.
Udo.
Oh.......poctop said:I really hope your capsule is not responsible for that and also i would really hope we get in the bottom of this ,
Dan,
Udo,kante1603 said:Oh.......poctop said:I really hope your capsule is not responsible for that and also i would really hope we get in the bottom of this ,
Dan,?.......you mean the pk87 in general or especially the one in my build?
As said it is really great soundwise,very close to a U87Ai.
That would be very bad financially,I have two from the group buy.....
And I measured the capacitance of it prior to mounting,it was close to 50pF,so spot on to the specs....
Hi Dan,poctop said:Udo,
no to scrare you Sorry ,this was just a tought i had bad capsule from the best provider , but we still can't exclude it from the deal ,
measuring capacitance at rest in something but once polarized if the capsule has lost his tension equilibrium or too loose and get suck to the back plate when polarized then there will be a output loss, but most proably covered with a rumbly mic , is your pair of mic behaving the same?
Yes,the sm7b is spec'd for -59,0 dBV/Pa / 1,12 mV/Pa,it is a dynamic mic.Seems to be too low too.sr1200 said:Mine is about on par with my SM7B which is ridiculously LOW output.
wthrelfall said:Dany
I removed the transformer connections, and the connections to the capsule, and also removed the fet and R11. original bom components elsewhere. Here are my voltages:
Phantom power is 48.6v
top of L1 - 48.6v
top of L2 - 45.9v
top of R18 - 48.6v
top of R19 - 45v
bottom of R17 - 45v
top of R17 - 23.18v
Zener 23.17v
FET drain pad 23.15v
FET source pad 0.089v
top of R12 23.15v
top of R13 42.4v
top of R14 23.14v
top of R8 41.8v
What is R9 & R10 doing? I got 0v there..
