Negative is the deep engravings,but this can be worked around by sanding and filling them,I did this with 2 component glue on my MK47 build,easy one.
But:The head is not screwed to the rails as on the new version,it is plugged in like the Neumann style,the rest is held by latching rails.
The plastic part (with that barcode on it) takes away around 1cm of useful inner length,I must get rid of it.
The latches don´t feel strong enough.
The pcbs go down to to bottom end,in the new one there´s a gap where I mounted my transformer.
All in all it seems to get weak mechanically when I do further disassembly,must think about it first.The new version feels way better constructed,and certainly has a better ground connection between the head and the rest.
Will post more pics when I´m at it again,for now I can´t go further (I have a real job too...
CU,
Udo.
