Matador
kante1603 said:I meant which capsules and transformers you will use,pardon my bad english,still learning....![]()
Oops, my fault you asked very clearly.
I'm using two K67 type capsules matched by Dave Thomas at AAMicrophones. They are essentially the same as those sold by Microphone Parts, but they are re-skinned with 6 micron Mylar. They should have slightly less high frequency lift in the 7-9kHz range as a typical K67 type capsule. Since I already have two "dark" versions using K47 type capsules, I'm hoping this pair has slightly more "air".
More sonic crayons to add to the box!
