spudstyle
- Joined
- Jun 5, 2012
- Messages
- 57
HellfireStudios said:A simple way to test the transformers wiring is to put a small AC voltage across the primaries
evanmurphy said:Hi folks,
Trying to get John's P-T87 wired up to the board and can't find a definitive color code chart for it. How far off am I ?
RT = red
SW = yellow
WS = Black
BL = green
I'm basing that off of the aurycle trafo so I could be totally wrong? Anyone?
Thanks in advance, and thanks Dany for such a cool project!
poctop said:Here is what my Clone sounds like the clip is very raw ( No pop filter to have an idea of the proximity effect ) but at same gain setting
D.
https://cdn.groupbuilder.com/groupdiy/u/39511/58d02819939b3.wav
Edit : when i say it is very very flat i am tlaking about the extra sweetness with the original capsule.
Got the year october 1979
Dan,
HellfireStudios said:Call or email John over at Peluso. He should send a wire color chart for your particular transformer.
-James-
poctop said:I was requested to post some sample in another thread so here it is again ,
Enjoy,
Poo, I just ordered his and figured it'd be in there.evanmurphy said:Hi folks,
RT = red
SW = yellow
WS = Black
BL = green
Sredna said:The lowest side is the output (XLR-side).
For example the AMI transformer has ~ 22 Ohms on the secondary and ~ 440 Ohms on the primary.
Sredna said:Sredna said:The lowest side is the output (XLR-side).
Should be about the same values for other T87-clones as well...
Dont be afraid to check things yourself, the low output problem some here had was because of following the colour codes blindly! 8)
atticmike said:Gonna start building my stereo pair today but there are some questions left:
What is the FET measuring gonna give me? I guess it for finding a matching pair in a stereo situation but not helpful if you go mono? Whereas I'll be building a stereo set so it is important to me. Is it better that I measure a bigger or lower voltage drain? I guess lower is better right? Any references value like 10.5V ?
A: it is the IDSS of the FET that you want to be low but arround 10ma you should be all fine , you can determine it with the 9V battery procedure has been posted by matador and it is on the first page of the build thread
And what does it mean to install R6 backwards? Doesn't it matter to what side i solder the resistor to the board? Or is this just a facility to support the measuring ergonomics?
A: yes easier to inject signal from the top of the board for biasing
I mean, I read through the thread and as this being the first time mic build I'm doing, I've got easily lost. Can someone post a quick succession of what's supposed to be done in a numeric order after stuffing the boards?
1- stuff it
2- bias it
3-use it
i suppose it is to measure the drain with a 9V battery and put this in the math form provided by the author which gives me the resistor value then?
see Matador procedure for IDss ,
