if you do a lot of close miking and have external preamps that have tons of gain to spare
I can confirm absolutely correct levels now,my readings have been a 35dB and 46dB of gain pot positions which equal -11db difference to an U87Ai!!!This is exactly what i wanted to see all the time-SPOT ON!
Mode | Front Diaphragm | | Front Backplate | | Rear Backplate | | Rear Diaphragm |
Cardioid | 0V | 47V | 47V | 47V |
Omni | 0V | 47V | 47V | 0V |
Figure-8 | 0V | 47V | 0V | 47V |
Marc Duchesne said:Yep, effectively there seems to be T13 transformers with reversed color code (compared to http://www.tab-funkenwerk.com/id133.html) for primary and secondary. I switches the wiring in mine and gained at least 10db on the output, which is enormous. It now behaves like my other good mic's... Excellent !!!
Marc Duchesne said:Yes, I double checked and I really had 420 ohms on the black wires, making it a 1:10 ratio transformer instead of a 10:1.
How I ended up getting less level as 1:10 config. I don't know. But it is now wired ok.
Yes,for me it was totally unusable for standard vocal stuff,so I didn't use it and wanted to take care later.....now it's working same as the originals- really!Matador said:Like I said previously, I'm shocked the microphones were usable at all.
Hello,spudstyle said:No, I will try this tomorrow. It's a behringer b2 pro if that can help (not the same version as kante1603).
