- Joined
- Jul 15, 2009
- Messages
- 2,312
with stock capsule cardiod only is possible ,Dan are saying I can use with stock "C1" capsule?,
D
tskguy said:Jess,
If you have a chuck d body the pattern switch is mislabeled. The middle position is cardioid the other two I correct if memory serves. As for the pop during changing patterns is normal. I usually make the polar decision prior to setting the gain. How does the capsule sound???
Eric
JessJackson said:tskguy said:Jess,
Eric
Thanks Eric,
I haven't checked it on an artist yet. I'm cutting Tyga on a Rick Ross record this week and although 87 isn't what i've used on Tyga for the last 7 years, (normally c12 / u67) I was going to cut it using this mic.
I do have a chuck D body. but why is there continuous loud pops and squeals in the right position. center (cardioid) is fine but quite high noise floor.
Somethings not right.
JessJackson said:Thanks pip,
ok so in the center it works as cardioid and sounds great, to the left sounds great and sounds omni.
To the right, its not as noisy as it was yesterday... the front capsule is on but it sounds duller on the front (less tops) and full on the back. with some now low level intermittent whooshing.
I have the same feeling here.Easy enough to check.Pip said:The reason I say this is if the mic is working in Omni then this points to the switch.
Pip said:JessJackson said:Thanks pip,
Check C2 make sure its OK. Also is your Capsule single or double backplate? Lastly is the switch OK?
Forgive me but I don't understand "sounds omni"? When in Omni as you turn (along its vertical axis) the mic and talk into it it should have equal loudness all the way around. So when in cardioid as you turn mic the sound should drop of as the rear capsule comes to bear on the sound source with the maximum drop off being directly at the rear capsule and then as you continue to turn the mic the sound should come back as you get back to the front. In figure of 8 the sound drop offs should only happen as the side of the mic faces the sound source. So two sides two null points. Sorry if I am being Master of the Obvious here.
JessJackson said:I checked capsule for shorts, no shorts. backplates are independent from one another / capsule seems good.
I checked switch for shorts and continuity at circuit board
in center position no continuity
in left position continuity between OMNI & CRD
in right position continuity between CRD & 8
it seems switch is good, output on cardioid still v low
having done more testing it seems that when in fig 8 only the rear diaphragm picking up audio. front of capsule not on.
HellfireStudios said:JessJackson said:I checked capsule for shorts, no shorts. backplates are independent from one another / capsule seems good.
Try reversing the front and back capsule connections on the PCB. If cardioid is okay and the front capsule works in figure-of-eight, then the capsule is the culprit. Technically, no matter the polar pattern selected, the head amp in the mic handles only one signal (i.e., there isn't a seperate head amp for each side of the capsule). So, if you're getting sound from any side of the capsule, the electronics are probably ok (excluding polarization electronics). Good luck.
-James-
