kante1603
Congrats!
On top of the pcb,is that residual solder flux or tears ;D
Udo.
Udo.
dissonantstring said:ok, this seems strange, checking voltages in my "fig.8 -less" mics:
In OMNI the FC BDY = 38VDC / RC BDY = 38VDC / 0VDC on FC CAP & RC CAP
In HyperC the FC = 38VDC & RC = 38VDC / 0VDC on FC CAP & RC CAP
in Fig8 the FC = 6.8VDC and RC = 6.8VDC / 0VDC on FC CAP & RC CAP
shouldn't there be some voltage on the diaphragm (either front or rear depending on mode)? ???
edit: BTW the mic actually does delivery sound in fig.8 mode, but it sounds a lot softer and more like Hypercardiod mode.
Hi Grant,dissonantstring said:i wonder if this is a common problem, i.e. should we let john peluso know his capsules have QA issues?
Are you probing correct and hold them really steady?Mr.GrinchSD said:Ok so Im trying to set my mic to exactly 11.05 but the voltages keep jumpin around. Like from 11.05 to 11.13 to 11.20 then it will go down to like 10.55 ????? Any Ideas
Hmmmm....o.k........drifting voltages over time normally is something related to parts like capacitors.Mr.GrinchSD said:CApsule is connected Fluke DMM and ya Im pretty sure im doing it right.
