Spencerleehorton
Does anyone have any helpful info on winding my own output txf?
I have an winding machine and a quite a few transformers that are a similar size to my other Carnhill output txf.
I have found that i need 28awg Enamel copper wire.
the E to I laminations need to be gapped with electrical tape to stop distortion of the core.
Pri A = 311 windings, wound in reverse (i have read its not essential to wind in reverse?)
Pri B = 311 windings, wound in reverse
Sec A = 524 windings
Sec B = 524 windings
Wind half of Sec B onto spool first 262 winds(then cut), then Pri B wound in reverse(311 winds).
Then wind Sec A(524 winds), then wind Pri A in reverse(311 winds), then solder and heat shrink to Sec B then wind Sec B to finish(262 winds).
question now is where would I put the earth in? And how wide thick etc would this have to be?
I've attached a photo of the txf that I wanted to use as doing a 1066 style output txf but it has two bobbins rather than one, separate for primary and secondary.
Can it be wound with two bobbins or does it need to just be one?
when it comes to winding it, i will try and tension it.
Regards
Spence.
Regards
Spence.
