I'm pretty sure that I have 10 x 10kA Mod-Pots that I can sell you...probably with your choice of shaft size and type too. PM me for more info.The only mistake I did was to reinstall the original 10K pots by wanting to keep everything as genuine as possible.
They are linear (as was the original output pot, which I find very strange), fragile and very unreliable. The push to mute functionnality, although pretty useful, has become very sensible and quite often keeps on getting stuck. They also feel terribly soft, I like hard to turn buttons.
I will for sure be replacing them for new A10Ks in the near future.
Thanks a ton! I forgot to tell you it was done, you're a big part of the project's success!It's looking great! Great that you got it all back working.
You're welcome! Glad I could help a littleThanks a ton! I forgot to tell you it was done, you're a big part of the project's success!
That's very interesting. Would I need to re-install the resistors if I replace the current pots with logs or would it make no sense?Neve never used log pots except for P&G faders. All rotary pots were linear and were mostly slugged with half the pot value from wiper to ground. This gives close to 10dB attanuation at the mid point. The reason for this is that LIN pots are much repeatable and much less error prone than LOG pots.
If you use logs you don't need the resistors.That's very interesting. Would I need to re-install the resistors if I replace the current pots with logs or would it make no sense?
I think what I'm seeing here is: When switch is Out (no Mute) the wiper is routed through the resistor on the back of the switch to the blue (presumably signal) wire on the other side. When the switch is In (Mute) the resistor is shorted to ground (green wire). So, with the pot turned full CCW, it is still going through that resistor (a summing R?) which is why it doesn't ground out the rest of the bus.Hi Ian,
I simply copied the original Neve wiring of another Audience Reaction Mixer:
It works very well on the other working pots/switches to mute the channel when pushed. I've tried testing continuity between all these pins but they do not make sense to me either tho so it is hard to understand what is going on.
That's what I figured when checking continuity. I previously thought the resistor had to always be between the wiper and ground (as Ian mentionned a few posts ago: "All rotary pots were linear and were mostly slugged with half the pot value from wiper to ground."). But that was the bus feed resistor itself!When switch is Out (no Mute) the wiper is routed through the resistor on the back of the switch to the blue (presumably signal) wire on the other side.
Looks great, congrats!!!Looking great in the racks thanks to @fffaustino 's original blue knob for the output gain!
It turns out that A3559 was one of three 32 channel TV consoles made for CBS in 1975. Apparently CBS sere still using a 150 ohm termination to define 0dBm so all the outputs had to be capable of doing this. It was this that spurred the change to using dBu instead of dBm at Neve. Here is a little video from Rupert.
