Spencerleehorton
Think I’m on track now with this build, would like to add adjustable side chain filter at some stage but best to get this going first!!!
The buffer amp is a part of the BA191 board. Input is "C" and output of the buffer is "B"Spencerleehorton said:What schematic are you following? The original Neve doesn’t have part numbers only values? The audio maintenance version has its own numbers?
C14?
The HPF should be infront of the buffer, between the L10468 secondary and buffer "B".Spencerleehorton said:Hi Thomas,
thanks for you help btw, so your saying if i want to put a HPF it should go after the threshold control and into C on BA191?
Also i have tried to mod this 2254 schematic to show just the compressor parts.
Could you also confirm it is the 270R resistor which i need to replace on BA191 for a series of resistors, its output is to J and to the last BC107 on original schematic.
Lorlin has both, MBB = shortingSpencerleehorton said:For the attack switch is a lorlin make before break?
Just checked my order of the lorlins and it doesn’t says whether it’s MBB or not, so will just have to check on MM!
Spencerleehorton said:need to find out exactly where all the voltage connections for psu are?
is there a power supply schematic?
it doesnt actually show where B+ is on any of the schematics that i can see?!!!
Spencerleehorton said:Do you mean that U with the 10R resistor to the output txf?
