Spencerleehorton
seems the schematic that ive posted is wrong? Ive disconnected signal from 283 at U input and im still getting output on pin 2?
anyone explain this?
Spencerleehorton said:well i seem to have found my problem but i also have another problem!!!
ive taken the PSU outside the case and now installed into another case which can now live about 6 foot away.
last time i checked the psu outside the case i didnt take the psu and toroidal away enough to make any differnce.
It has to be at least 1-2 feet away to make any difference.
noise is now taken care of but there now seem to be another gnd issue.
when i plug a bass into a DI and then preamp it, ive checked without the 2254 first and signal and sound has no issues.
but when put through the 2254 if i dont touch the strings there is hum!!
so this seems to be a gnd issue?
this is with the volume down on the bass btw
Spencerleehorton said:Well I've connected pin 1 on input socket to 0v and no change, still getting hum when not touching strings?
I've continuity tested from iec gnd to pin 1 input and it is connected?
