Kevin
That looks really good. Glad it worked out so well !!
Since building two detectors and sidechains meant using two boards; I decided to go one step further. The VCAs I used are the 202XT's, which are each composed of 8 x SIL VCAs for noise reasons. Since they are all used in the same pole, I built the second channel in each and polarity-flipped the signal through it, re-inverting at the end, to re-sum back in the same polarity. (You have to remove one sidechan-summing resistor to prevent the signal nulling...)
The signal thus passes through the VCAs in opposite polarity, and some of the residual VCA distortion is thus canceled. -This is how the SSL 9000 J and K series console center section buss compressor does it: the "Superanalogue" version... except that they do it with half as many VCAs in each pole, since it's getting a little expensive by that point!
2. Link Left + input to right – input on both boards
3. Link right + input to left – input on both boards
4. Do steps 2 & 3 above to the outputs of both boards.
:thumb: :thumb: :thumb: :thumb: :thumb:
Keith
-I reckon you don't need those ±12V links, in fact having them means that if either regulator has a slightly differenct notion of what is precisely 12 volts, there could be a noise issue... try removing them (assuming that you have the slave ratio board fed it's ±12V from the main slave board, of course!) and seeing if it shill works... it should, and since you won't have the two regulator outputs connected directly to each other, there should be no chance of a "fight"...
khstudio said:[quote author="Rob Flinn"]Kevin
Well the 12v has to come from somewhere & I thought I read to hook it up there... :? ???
Kevin
Rob Flinn said:[quote author="khstudio"][quote author="Rob Flinn"]Kevin
Kevin
